Strofoam Caul For Sound Port Backing http://www-.luthiersforum.com/forum/viewtopic.php?f=10117&t=23163 |
Author: | Chris Paulick [ Wed Jul 22, 2009 8:51 am ] |
Post subject: | Strofoam Caul For Sound Port Backing |
I was HHG gluing some .050" ebony veneer to the inside of the upper bout for a sound port backing and was thinking of a quick way to make a clamping caul for it. I remembered back to my Discus fish breeding days when I used styrofoam under the aquariums to level them out from uneven surfaces. So I bent the veneer on the Ibex and I glued a piece of Styrofoam to a piece of wood and clamped it up. Perhaps this might come in handy for some other things. I understand this might not work in a situation where a lot of pressure is needed for a long time because the foam will compress and conform to the shape and may loose the clamping pressure. But it seems to work in this case. |
Author: | Chris Paulick [ Wed Jul 22, 2009 8:53 am ] |
Post subject: | Re: Strofoam Caul For Sound Port Backing |
After one hour the strofoam conformed to the shape but it was long enought to let the glue set and hold. But I wonder if this might have possibilities for making contour sanding blocks? Some food for thought and something to play around with I guess. |
Author: | Dkeddy27 [ Mon Feb 04, 2013 9:17 pm ] |
[That's Clampologie at its best! ![]() |
Author: | Chris Pile [ Tue Feb 05, 2013 12:28 am ] |
I used to clamps to fit curves from wood roughly sawed to the shape, and then used automotive bondo for a form fit. Wax paper kept it sticking to the guitar. |
Author: | Beth Mayer [ Tue Feb 05, 2013 4:25 pm ] |
Nice, Chris. I used Friendly Plastic to make my caul for this a'la Robbie O'Brien. It can be re-used if you put your port in the same place on the same shape guitar. If not, just drop it back in the hot water for a couple minutes ![]() |
Author: | Chris Paulick [ Tue Feb 05, 2013 4:53 pm ] |
Yeah but you have to have something to do with that foam packaging material. Go Green.. ![]() |
Author: | Beth Mayer [ Tue Feb 05, 2013 11:17 pm ] |
I'm all for re-purposing things!! |
Author: | Dave Sayers [ Fri Feb 15, 2013 3:40 am ] |
I use blue laminate underlay in layers for the same purpose. It can easily be cut with scissors and the glues doesn't stick to it. |
